Ssl Certbot
**My website URL is:**https://Andrea scam.ml
What I’m seeing is:
I’m using this software:
Additional information:
Help me out in using a certbot to get ssl certificate and configure it with infinity free.
Certbot works best if you have full access to the server configuration. So to get SSL on your own server or VPS, Certbot is great. But in basically any other environment, another way to use Let’s Encrypt tends to work better.
Unfortunately, there is no way to use Let’s Encrypt that works properly with InfinityFree due to the limitations described here:
okay!! Then help out the best way get a ask certificate for my website.
Does anyone else provide ssl certificate for free. I know Cloudflare does so. But if there any other CA which gives free ssl. Which is also compatible with Infinity Free.
