Make sure that the common name of your SSL certificate is your root domain (http://victoriali0508.com/) or else it won’t let you upload your domain. While I’m not sure Wildcard does work here but make sure it is just a SAN extension and not the common name of your SSL certificate.
Well when you registered that SSL certificate you should have used your root domain to make sure that the common name registered is victoriali0508.com and not *.victoriali0508.com or else you won’t be able to upload your SSL certificate here.
Try asking your SSL certificate authority about it they might be able to help you.
