Ssl certificate delay
http://christinme.epizy.com/
NOT READY
IT HAS BEEN MORE THAN 24 HOURS NOW
You must have copied a CNAME record incorrectly. Please make sure there are no extra spaces when you paste, and that the page is not being automatically translated (As sometimes this can change the text)
Thanks.
Then you probably have not setup the CNAME records correctly.
A quick DNS lookup by hand tells me that this is indeed the case.
It doesn’t help that you deactivated the account holding that domain.
