SSL certificate error: An unknown error occurred. Please try again later
(http://yenfashion.infinityfreeapp.com/)
When i start using ssl from ZeroSSL, i got this error: SSL certificate error: An unknown error occurred. Please try again later
How can i fix this?
Thank you!
You still need to install the SSL private key and certificate to your account. See: How to install an SSL certificate
In your control panel, the certificate box is empty, but the CSR box does not. This means you used the “Generate Key/CSR” button. Please note that you don’t need to use this function if you use our free SSL certificates, and that using this function removes any private key and certificate uploaded before.
