- Changed nameservers (successful)
- Added Let’s Encrypt SSL (successful) Certificate enabled
- Added .htaccess to htdocs with script
- Entered Softaculous and attempt to install Wordpress using https (FAILED)
- Changed to http and the Quick Install button says Custom Install (does that mean I have to manually load WordPress?)
- As a side note, I also had the disable WordPress Cron Jobs checked
What should I try next?
