SSL certificate error: The provider returned an unknown error. Please try again later.
I’m trying to renew my SSL certificate using the ZeroSSL service but it keeps failing and gives the above mentioned error.
If you try using GoGetSSL, does it work? ZeroSSL has been known to be a little flaky at times.
Haven’t tried it yet because ZeroSSL seemed better, but lemme check.
Tried this. GoGetSSL worked indeed, I thought I was doing something wrong before for ZeroSSL to not work, but it seems it’s flaky.
