Hello, someone should guide me through on how to create a free SSL Certificate on my infinityfree hosting website.
You can’t create a free SSL certificate. An SSL certificate can only be created by a recognized SSL certificate vendor, which is usually not free. You can use SSL certificates from most SSL vendors on our hosting, as long as it’s a generally recognized and trusted SSL vendor.
Okay noted, but my question now is that, is infinityfree hosting operating on a linux server or windows server? Moreover does ssl certificate comes with your hosting?
I guess you ask for this reason
HTTPS is enabled on all websites by default. However, the default certificate is self-signed, meaning browsers will show a security warning.
You can install your certificate using the SSL/TLS section in your control panel. For more information, see this article.
Additionally Getting SSL certificates from sslforfree.com or zerossl.com - Docs - InfinityFree Forum
