SSL Certificate
Hi !
Actually i checked my domain in SSL checker, It says SSL certificate installed Correctly. But When i open my website in browser, it says unsecured. Pls Help me…
www.royalcurtainsandblinds.ga
@SSLCertificate said:
Hi !
It seems that the certificate authority is invalid (Blank).
Can you tell me where did you get the certificate?
Hi !
If the SSL certificate checker says the installation was successful, then the installation was successful and your website is secured.
However, browsers tend to remember old certificates for a while, even if they are invalid. That’s why we recommend to verify the installation with a certificate checker: browsers are not reliable for that!
Hi !
CA chains cannot be installed on free hosting, so that’s normal. It also doesn’t explain why you would get an SSL certificate warning.
Hi !
Hi!
It seems like you have enabled Flexible SSL on your website,and that is why it is ruined.
Please see this topic here The Weirdest Problem With HTTPS!(NOT KIDDING) - Hosting Support - InfinityFree Forum or just select Full SSL to get it back as it was.
  1. Register your website on Cloudflare.
  2. Install Really Simple SSL on your WordPress. (You can uninstall it after you activating it in a few hours).
  3. If nothing happens, proceed to number 4 step.
  4. Change your site address with “Https://” in General Setting on your WordPress site. prntscr.com/jfbl5i
  5. Configure your Cloudflare to Enable:
    *AUTOMATIC HTTP REWRITES: Screenshot by Lightshot
    *ALWAYS USE HTTPS: prntscr.com/jfbheo
  6. Follow my PAGE RULE SAMPLE (See Attached Screenshot): prntscr.com/jfbfsy
  7. Wait for a few hours. Browse your site. When your site don’t load normally, change Cloudflare setting from Flexible to Full.
  8. Feedback.
Hope it helps. :slight_smile:
www.mauwiks.cf (Site’s On Going Construction)
  8. Feedback.
Yes but he MUST select Full SSL instead of the default Flexible,otherwise the website will be ruined as mine was,you can see that on this topic:The Weirdest Problem With HTTPS!(NOT KIDDING) - Hosting Support - InfinityFree Forum that I had created.
Nice steps,anyway.
Is your website going to be about tech?
Whether Full SSL is required or not depends on your website code. Well written code should work fine with Flexible SSL, but many scripts cannot deal properly with the apparent contradiction of getting accessed through HTTPS but not handling SSL itself.
Full SSL is still recommended though. There is no reason to use Flexible SSL on InfinityFree, and Full SSL is more secure. You should set that immediately after adding your domain to Cloudflare, no need to wait for that.
When it came to Pagerules then @mauwiks your page rules are following some error and it can be better than that! My recommended Pagerules are!
As we know there are limit of 3 rules thus.
1. To save Bandwidth and to use less server resources!
https://.yoursite.com/
Always Online - ON
Browser Cache TTL - 24 Hours
Cache Level - Cache Everything
Rocket Loader - Automatic
Automatic HTTPS Rewrites - enable
2. For WP-Admin Dashboard
if you are using WP then there should be no cache at Admin Dashboard it have to update frequently thus
https://yoursite.com/wp-admin/
Disable Performance
Disable Cache
3. If you use AMP
https://.yoursite.com/amp/
Disable Performance
Disable Security
Disable Apps
CAMT
  8. Feedback.
Nice steps,anyway.
Not really. It’s just a simple personal development blog. I have another Blog to build for that. :slight_smile:
Sorry, not that familiar with coding yet. I told what I find working for me. :slight_smile:
Always Online - ON
Disable Performance
Disable Cache
3. If you use AMP
Disable Performance
Disable Security
Disable Apps
CAMT
Thanks Buddy! Will try it on.
