Hello, i hope all is well.
I was wondering what the process was for renewing SSL Certificates after three months? Is it as simple as just requesting one as before, and replacing it in the control panel?
Thanks,
Paul
Thanks,
Paul
You should get a notification 30 days before the expiration date provided you chose that option when you installed the existing certificate. I just went through this process, it went pretty easy, link to my post about that is below.
