Hello admin I want to ask. I have my own domain name. my server name is full. I want to plug in Cloudflare. then how to how to mengksang Cloudflare with own domain
the same question is from me! cloudflare asks for nameserver change, if i change it, my website would be down? or will work fine?
You can use your own nameservers with InfinityFree after the domain is added to your account. You must use our nameservers to add the domain to your account, but after that you’re free to use external nameservers. As long as you make sure the DNS records in Cloudflare are correct, you’re good to go.
so if i change nameservers my website won’t be down?
Assuming your own nameservers have been configured correctly, your website will keep working without any interruption.
thanks a lot, admin and all the people who helped out my website crunkers.com is almost ready and will be live by 1st of November!
