For some time, we’ve been running the MonstaFTP file manager on a somewhat experimental cloud hosting platform. While this platform has generally worked quite well, it appears that this system has experienced a malfunction causing the file manager to go down.
A backup server has now been set up with the file manager which should allow you to use the file manager again as usual while we will look into what happened with the cloud system.
