SSL error code #4
When attempting to renew the SSL certificate (Let’s Encrypt) for my website, I continued to receive the error and was unable to figure out what I should do.
Did you setup a TXT record for _acme-challenge.connoruhrig.com in Cloudflare? If so, can you please remove it? And make sure the CNAME record is set to “DNS Only”?
For some reason Cloudflare returns it’s own TXT record for _acme-challenge.connoruhrig.com, which is different from the TXT record that we put on acme.infinityfree.net for your domain.
I checked your DNS records again and they seem even worse than before. It looks like you change the previous record from a CNAME record to a TXT record.
Please delete ALL records of type TXT for the subdomain _acme-challenge. And then add a record with type CNAME that points to the value shown in the client area.
Up to 24 hours. And Cloudflare’s nameservers are fast, so it’s probably a lot less than that.
@Admin
I tried again after updating the DNS records and I’m still receiving code #4
All of the TXT records have been removed and have been replaced by CNAME records.
