My website’s certificate is not approved I did everything right I need help with this!
Website: https://alperenhakli.ga/
Welcome!
SSL is working on your website! Is this what you are looking for?
Admin
Split this topic
#3
4 posts were split to a new topic: Ssl error help!
Admin
#7
@Alperenleaks I have checked your certificate and it seems to be working fine from here.
No it’s not working properly, I want it to light green
Seriously? The green card doesn’t matter, all is good as your website open with SSL fine.
KangJL
#10
Then follow this guide
You can use CloudFlare full mode. Replace the SSL cert with self-signed cert when expired.
What you say doesn’t matter to me because I don’t use Cloudflare.
KangJL
#12
Then you will not get this
The choice is yours
Admin
#13
I see a closed padlock on your site, which means the certificate is valid and all resources are loaded over security connections.
If you were hoping to get a green lock, then I’m sorry to disappoint, because most browsers don’t show green locks anymore.
system
Closed
#14
