SSL Error
Hi, I cannot install the certificate I created on InfinityFree. It gives an error. Please help me
What error are you getting? Are you talking about the default certificate or the new InfinityFree SSL feature?
Create Key / CSR with CSR and generated key. Then copy and paste the SSL Certificate I created in InfinityFree into the Certificate section
What error?
InfinityFree SSL
@Admin
Screenshot_1
You also have to upload the Private Key from the Client Area to the Control Panel, before uploading the certificate from the Client Area to the Control Panel.
