Hello, I always got an error while trying to configure the ssl certificate I got for free. I typed the private key and the certificate key, then pressed the install certificate button and got the following error: The certificate you have entered does not match the current private key. (I clicked the generate csr button during the transactions, I entered the information, I clicked generate, then I clicked the upload certificate button) (I used google translation)
Please search the forum before posting.
Are you using the free SSL certificates we provide? If so, please note that the client area generates the private key for you, so you should NOT generate one through the control panel. Please make sure you’re following the relevant instructions:
