SSL Error
I created an SSL for my subdomain. First i use SELF SIGNED (SSL) but that’s not working, i remove the certificate and add new Let’s Encrypt SSL i install the cerftificate but the website don’t have the podlock and says the certificate is not trusted so i check the certificate in here. It shows the certificate provider is Let’s Encrypt But if you go tot he website it shows a :information_source: The certificate provider is not trusted
Most likely need to do this
That’s normal. The SSL support on free hosting is a bit… limited. It works in most browsers, but some automated tools and checks complain.
In short: if you see a green lock yourself, it should be all done.
As for not getting a secure connection yourself, see @KangJL’s post.
