You’re including your files from http://yyuinfomedia.com/
Not http://yyuinfomedia.xyz/
from WP settings, change your url to http://yyuinfomedia.xyz/
Hi I just started my site, with my own domain, and have been trying to get SSL error 525 to go away. Now that I found this form, I know that’s on my end. I’m just looking for an update for about how long you guys think it will be until the issue will be resolved.
The full fix will probably take a while. It could take months. It’s highly recommended to implement one of the workarounds instead of waiting for us to fix this issue.
I can still access my website, and I use WordPress… However, after going through the steps for SSL it was approved, I did all that was required. I still don’t have SSL and it now says my CNAME Is Not Ready… However, I got the Key, and Certificate earlier. But now, did it change its mind?
Please note that this topic is about SSL errors on some websites, not about the new SSL feature. If you need help with the new SSL system, please post a new topic in the Hosting Support category or reply to the announcement post.
Only a suggestion.
if you want ssl for your site, you might consider using CloudFlare.
They provide free flexible ssl without setting anything up.
Plus, it’s automatically do the transfer for you.
Hi,
HTTPS/SSL is not working on my website and there was a recent security issue.
Are there any updates on this situation?, as I am concerned for the security of my MyBB forum.
Thanks in advance.
Did you try implementing the workarounds suggested?
Please note that an SSL certificate does absolutely nothing to prevent your website from getting hacked. It protects your visitors from their connections being intercepted and their connection to your site from being spied on or manipulated. If your website code has a security vulnerability, you need to make sure you are running the patch if available, or have implemented the suggested mitigation.
This topic was automatically closed after 23 minutes. New replies are no longer allowed.
