I have a subdomain: postbook.rf.gd . It can be visited by http:// and https:// also. Can i redirect all http:// to https:// . I am not using wordpress. I am using other script.
Please create new topic.
If you have any problem or question then please create a new Topic instead of posting here
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ https://%{SERVER_NAME}%{REQUEST_URI} [R=301,L]
is it for .htaccess
yes
bruh checking your domain I realized that you installed the paste before the ssl I recommend you uninstall the paste Install the certificate and install it again
Especially I installed ssl first, the problem is routing.
You have to redirect like this in all ssl’s
