how to generate ssl/tls key and cerficate
Please make sure you fill in ALL the fields in the form. If the field does not apply to you, enter something like NA
in them, but all fields must be filled for the CSR generation to work.
but key not generated its showing empty
Go-to Ssl certificate on the cPanel. Click generate CSR and fill all the fields
i click but its not generated its empty
