Website URL
earlytester.com
(please specify the URL of the site on which you are experiencing the problem)
Not Secure.
Eventhough SSL is installed.
In chrome privacy and security enable always use secure connections and open earlytester.com
It says not secure.
(please share the FULL error message you see, if applicable)
Well the certificate you have is expired, so that makes sense.
Not only is your certificate expired, but your website is not forcing all connections to HTTPS, so even when you update it someone visiting over HTTP will get that notice.
The following articles may help:
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client…
After you’ve enabled SSL for your website, you’ll probably want to redirect all traffic on your website to the https version of your site. There are multiple ways to do that. Let’s compare some commonly used ways.
Using script configuration
Some scripts (including Wordpress) have a setting which allows you to set your website URL. By changing this URL from http://example.com to https://example.com , the script will probably redirect visitors to the https version of your site. Even if your scrip…
system
Closed
May 24, 2023, 5:37pm
#4
