okay i typed @ on name!
third is target what should i type in target option?
Find the Main Domain after logging in the Client Area and clicking the account with the domain in it. Scroll down to “Account Details” and you can find the Main Domain that you need to copy and paste in the “Target” field. After creating the first record, input @
on the second record’s “Target” field.
okay thanks ! first step is over now ! And now 2nd step is also a cname??
Yes, it is.
okay! what should i type in Name* and Target* option
Here are the things to type in these fields:
Target: @
Thanks ! next is mx record! Please help me to complete few more steps!
The name for it is @
, the value is mx.epizy.com
and the priority is 10
and what in type* option ? MX no?
And the type: yes, it is MX. I forgot it.
Okay ! its done! Thanks Again!! And the last step remain please help me out in that!!
Other subdomains? We don’t have any right now, so if you would create another subdomain, give as type of the record CNAME, as name the name you gave to the subdomain, and as value @
The last step is this will be written on top!
Make sure all A, AAAA, and CNAME records pointing to proxied records are also proxied to avoid exposing your origin IP.
Can you give me the screenshot of the DNS records again, so that I can see whether the records are proxied with Cloudflare or not?
Ya! wait i’ll send!
They are all proxied, so you would not need to set them all as proxied.
Okay what i do next???
You don’t need to do anything, for now, except to go on the “Crypto” page and make sure the SSL option is set to “Full”. If it isn’t, change it from “Flexible” to “Full”.
