SSL Issues
My website URL is dosermind.com:
What I’m seeing is: cant provide secure connection
Additional information: If I check the ssl it says that I have but I still cant use the https
You tried connecting via https?
I just tried to access https://dosermind.com/ and I get a “Error 525 - SSL handshake failed” error from Cloudflare.
This is caused by the fact that you’re using Cloudflare in SSL “Full” mode, but you have not installed an SSL certificate on your account. You will need to install a valid SSL certificate on your hosting account, or switch Cloudflare to “Flexible” SSL mode.
You can find more information about this here:
