Hi, I bought an SSL from Namecheap(PositiveSSL Multi-domain), and the domain I registered is example3.com. I tried to install it by following the steps.
The private key is uploaded, but the certificate is an error showing: The certificate uploaded is NOT for the domain name example3.com (example1.com was seen). Please if anyone faces the same situation or anyone can help will be appreciated.
Thank you for your reply. I tried to use the free SSL certificate, which is Let’s Encrypt instead of Namecheap. After installing the SSL, my domain still remains insecure warning. I tried to redirect HTTP to Https with .htaccess. Can you kindly let me know how can I do next?
I checked your domain but it’s not hosted by us right now. If you still need help with this, can you please make sure that the domain name is pointing to our servers?
