I was created SSL at comodo Trial SSL and succes.
i’m upload my cert ssl in epizy panel ssl, it was success
but event i’m visit my site in https mode. Cert SSL not pair and show invalid SSL.
I’m see again ssl at cpanel epizy is good. But not in visit.
sorry for my bad english and bad tenses
Setting up certificate can take a while, wait please and provide your website URL.
Did you follow this guide when setting up the SSL certificate? How to install an SSL certificate - Docs - InfinityFree Forum Regardless, be sure to check the “After installing your certificate section”.
I know how to install in cpanel without guide. Now ssl can be access. My feel Your Server is bit long to Install Certificate than other hosting
@richardhaas said:
@Admin said:
Did you follow this guide when setting up the SSL certificate? How to install an SSL certificate - Docs - InfinityFree Forum Regardless, be sure to check the “After installing your certificate section”.I know how to install in cpanel without guide. Now ssl can be access. My feel Your Server is bit long to Install Certificate than other hosting
A bit snotty, but if you didn’t already know, signing up and using this service is “as-is” as stated in thier terms (Terms of Service - InfinityFree ; Section 2). Please read it over carefully.
@richardhaas said:
The guide doesn’t just explain how to install an SSL certificate, is also explains something about the verification afterwards. Like the fact that some browsers cache SSL certificates, so you may not see the new certificated yet even if it has been fully installed already.
I should add that SSL installation can take up to 60 minutes to complete, but browser caches last much longer than that.
