I have added SSL Certificate and it’s been a few hours. It has still not been updated on the website. It is still showing unsecure.
Follow steps in following post!
[ some blog post about getting SSL certificates ]
Did you even read the post or do you just post this link immediately whenever you see “SSL”?
By showing “unsecure”, do you mean that the website loads but with a Not Secure banner in the address bar? Or do you actually see a big red SSL Error page?
If it’s the former, then it’s possible that SSL was enabled successfully but you’re just not using it yet. After installing an SSL certificate, you actually need to configure your website to use it.
This article has more information about that: How to make your website use HTTPS (SSL) - Docs - InfinityFree Forum
If it’s the latter, then it could just be that your browser has cached the old SSL certificate. Please try using an SSL Checker or just opening the website in private browsing mode to see if you can see the website that way.
thank you. I understood where it went wrong.
