Did you change the Cloudflare account with the new nameservers? If yes, you need to wait 72 hours, and then turn on all orange clouds (if they’re off) on the Cloudflare dashboard, or configure 1.1.1.1 on all your devices (downloading the app on the mobile device and configuring the DNS by following the instructions here on your desktop devices).
I’m not changed any account before…but after it is not working i m login with cloudflare…and cloudflare provide me new dns for update…till that i m not updated the nameservers. What I will do and how long it will take…
If i will update the nameserve then the problem will be solved or not…
Please suggest me in description bcoz no one is surfing my site without ssl.
No dear…Actually the domain name that is show under my account it is always show suspend domain…but my site going very well…
Can you tell me ip address for A name …
I think if you have remember someone has provide me ip address for update like…187.33.102.44…It is not an ip it is an example…
Please provide me specific IP address…then I will update and my site will be live…Please check
Then ping the Main Domain, then copy its IP, delete the CNAME record and create an A record with as name @ and as value the IP you’ve got from the ping. However, I’ve answered, “Maybe your account is suspended”, and I suggest you to check the Client Area for more informations about the suspension.
However, 187.33.102.44 is a Brazilian IP that doesn’t have a server installed, and doesn’t correspond with 185.27.134.xxx.
Maximum 24 hours for the world to see it; immediately with 1.1.1.1 configured on all the devices. Even if “immediately” is not the right term for it, because your account is still suspended. So wait 24 hours even for you to access it, or check the Client Area for the instructions of what you should do, or, if the domain was removed from the account where is your Main Domain, re-add it on the account by using the nameservers ns1.byet.org and ns2.byet.org and then put back the Cloudflare nameservers.
