SSL not working
User name : epiz_28842535 Website rockgarden.online
Generated Private Key and Certificate through both Let’s Encrypt and GoGetSSL. Also tried Self signing. In all cases after I upload the private key and then the corresponding certificate I do not get any error. However in the " Install the SSL certificate on rockgarden.online" it shows that the certificate is not installed as per below screen shot.
I first tried the GoGetSSL private key & certificate which didn’t work. Then I tried Let’s Encrypt private key and certificate and that too didn’t work. I didn’t get any error after uploading the private key and certificate.
Prior to trying these 2 I had tried self signing certificate by clicking on “Generate Key/CSR” however that failed to work as well.
i am also having the same problem. I created the cname records and created an SSL certificate. I then entered the issued certificate in the control panel. I’ve been waiting for about 30 hours, but it still shows I don’t have an SSL certificate on my site. However, I did the same on my other site and the SSL certificate was instantly uploaded to the site.
My site: aeklink.ml
IP: 185.27.134.60
See #system-issues
System problems with SSL appeared a long time ago. So they must have been resolved.
I thought admin confirmed that system issues got resolved.
I agree that the system issues topic says it was resolved, however there may be a new issue with it.
Can you try following the steps in this video exactly?
Thanks
Thanks a ton for your response. Yes, I have done exactly as per video. Have tried the same multiple times. Also have tried with both free certificate such as LetsEncrypt and GeoSSL.
Unfortunately you might just have to wait for Admin. There may be something messed up. Can you please provide a domain so it will be easier for him to check?
Thanks
My domain name is rockgarden.online
Maybe try using win-acme for Let’s Encrypt or GoGetSSL’s site for gogetssl SSLs.
IF YOU HAVE THIS PROBLEM
Please follow this flowchart.
The video:
Please do not post here is you are experiencing a none-SSL related issue!
Thanks.
5 different websites, none of them show any sign of SSL working
Domain Name: enpherest(dot)com
Username: epiz_28857991
Verified pointing to correct nameservers (ns1(dot)epizy(dot)com) (ns2(dot)epizy(dot)com)
Verified correct CNAMEs as well, only seeing the first one
Domain Name: nolanmeerdink(dot)com
Username: epiz_28849244
Verified both correct CNAMEs, but not finding either
Domain Name: studiokalona(dot)com
Username: epiz_28849316
Verified Private Key and Certificate Uploaded
Status says “Certificate not found” anyways
Domain Name: fadeinband(dot)com
Domain Name: enph(dot)great-site(dot)net
Username: epiz_28841032
Been trying to get this to work over the past three days with no sign of success
username: epiz_28117283, websit url: tedllanes.gq
I also have Err_ssl_protocol_error and I did changed it from https to http
Should i try to get an SSL certificate with Cloudflare until the problems are solved? Will I lose the current certificate I got from Let’s Encrypt or will it make things worse?
You can set Cloudflare SSL to “Flexible”. It will not mess anything up, and it is better than nothing. However, you will want to install a certificate on InfinityFree once the issue is solved, and change Cloudflare to “Full” for the best security.
Thanks
Hi,
domain name: pasdegiblotte.com
username: epiz_28857368
The same problem occure after moving the page to another account
( due to “Website IPs 185.27.134.116 down” ) - previously it worked for me:
  1. Domain Name: nowakosie.pl (Let’s Encrypt) and nowakosie.epizy.com (GoGetSSL)
    Username: epiz_28832280
  2. Domain Name: nowakowscy.epizy.com (GoGetSSL)
    Username: epiz_28831722
The same thing will happen because the SSL is down for all accounts, please just be patient.
Thanks.
Domain Name: opticaponte.ga
Username: epiz_28860622
Verified pointing to correct nameservers ns1.epizy.com, ns2.epizy.com
This is an internal error, so just be patient!
