Hi, Currently having an SSL certificate issue with the website above.
I’ve received the SSL Certificate, Along with the private key & Certificate.
The key provided is not valid when uploading the private key in the Control Panel (SSL/TLS).
Any suggestions in what i should do would be appreciated.
Thanks
What is the error?
Are you sure you copied the lines that say ———BEGIN PROVATE KEY———
and ———END PRIVATE KEY———
Oh, Didn’t realise you had to do that.
