Hi, i want to install an SSL certificate. I have a private key and a certificate via InfinityFree but i always get the error saying: ‘The certificate you have entered does not match the current private key.’ I litteraly copy and pasted the keys from the site.
I’m using this software:
I am using the SSL certificate and SSLconfigure from infinityFree.
I checked the private key in your control panel and the private key in your client area, and I can clearly see the text is different. And I see there is a CSR there, which means you’ve used the Generate Key / CSR function, which you don’t need to use.
Could you please try to install the SSL certificate according to our official instructions?
hello, i want to install an SSL certificate. I have a private key and a certificate via InfinityFree but i always get the error saying: The private key you are trying to upload is not valid.
And for the certificate the error saying: The certificate uploaded is NOT for the domain name aly-nails.com ( was seen) .
