you will still need that plugin, trust me, it will redirect all http request to https.
if you already install Wordpress on http
, then you’ll probably need it. It is to redirect all http
to https
allright ok… thanks buddy
okay thanks ! hope this time works…
i clicked on refresh dns status
and says:
eldesayunoorganico.com: There are currently 1 TXT record(s) on the verification subdomain. Please remove any TXT records and only set the CNAME record. Please note that DNS changes can take up to 24 hours to take effect.
www.eldesayunoorganico.com: The required CNAME record could not be found. Please note that DNS changes can take up to 24 hours to take effect.
Where did you see this error?
i only added 2
here
could be that 24hrs? i only have add MX record to mail thing and just 2 on cname like SSL asqued me to do it
I think it is an InfinityFree error.
Remove the
_acmechallenge.www.eldesayunoorganico.com. (this is very wrong) from below CNAME Record and then replace it to _acmechallenge.www
Same as the _acmechallenge.eldesayunoorganico.com (this is very wrong) replace it to _acmechallenge and wait for an hour.
maybe wait 24 hours and let see?
bro
its added by the system !!! not by me
i only add this:
_acme-challenge
and this
_acme-challenge.www
that’s weird bro! try removing and readding it back and wait for an hour to verify the dns status
can remove
its add by the system
now its fine i clicked on dns refresh status…
Your CNAME records are valid.
Now request a certificate by navigating to your ssl certificate tool
come on katufoo
where i request???
Can you send us a screenshot of your dns status? At ssl certificate tool, like at the very bottom of it.
