As I can see the cpanel not allowing me to create subdomain like: sub2.sub.example.com
. But I’m able to create sub of a sub to a ‘domain’ example.rf.gd
. Why can’t it be possible with regular subdomains of top-level domain?
@MrJunior said:
As I can see the cpanel not allowing me to create subdomain like:sub2.sub.example.com
. But I’m able to create sub of a sub to a ‘domain’example.rf.gd
May I know what extension you use in your subdomain?
What I mean is that instead of saying sub2
you should say the real sub extension you want to make.
@UnknownLolz
I believe that I explained enough, but:
Main domain: mrjunior.ml
Sub: test.mrjunior.ml
I want: lol.test.mrjunior.ml
No subdomains created yet, just example.
@MrJunior said:
@UnknownLolz
Main domain:mrjunior.ml
Sub:test.mrjunior.ml
I want:lol.test.mrjunior.ml
If you are adding a subdomain for your subdomain on this way:
Then it will not work
I knew it, right? Thanks for shitpost.
@UnknownLolz wdym lol. You showed me the way and said that It not working. Also, note that I’m not stupid and I’ve tried it already…
Where. Is. The. Sense. Of. Your. Answer?
Being able to create subdomains of subdomains is officially not supposed to be possible. The fact that you can do so now for some (free) subdomains is a bug already. Sub-subdomains are supposed to be a premium only feature.
Bug or feature lol, you gonna remove it?
I can’t remove it (only iFastNet can), and so far the request I submitted one and a half years ago has not yet been implemented.
To create a subdomain of a subdomain, you can create a subdomain first, and then, open Addon Domains page.
Then separate the subdomain page on the left part of screen and Addon Domain on the right. Type your subdomain you just added into the “Addon Domain” form.(e.g. you created sub.rf.gd?then you input sub.rf.gd)
After that, click “Delete” of your subdomain, and quickly add the addon domain. It can success if you are quick enough. (Subdomain created on rf.gd can success, but on epizy.com can’t)
So now the subdomain “sub.rf.gd” become an addon domain. You can continue creating sub2.sub.rf.gd.
@yezhiyi said:
To create a subdomain of a subdomain, you can create a subdomain first, and then, open Addon Domains page. …
But it is a cheating method (doesn’t violate the TOS).
@yezhiyi said:
To create a subdomain of a subdomain, you can create a subdomain first, and then, open Addon Domains page.Then separate the subdomain page on the left part of screen and Addon Domain on the right. Type your subdomain you just added into the “Addon Domain” form.(e.g. you created sub.rf.gd?then you input sub.rf.gd)
Hey,
It won’t work FYI because you can’t add subdomains on the Addon domains and also besides you can’t add it cause it will just say “error domain is already assigned”.
I tried this many times and also tried this back from April and doesn’t work.
Also the Addon Domains
settings is ONLY for primary TLD’s (such as ydomain.com) and is NOT for subdomains, it does not accept any subdomains.
