Hey! I added subdomain pobeda.j0101.com
then I added ZeroSSL to that subdomain because Let’s Encrypt doesn’t support that.
but there is a message during several days already - current destination (CNAME not found) even though I added that cname to cloudflare as well.
You have the Cloudflare proxy enabled on the subdomain, which won’t work.
Please disable that, and then give it half an hour to update.
What makes you say that? Let’s Encrypt officially supports all domains which should include your subdomain. It’s even the recommended provider by us!
The “Not for Free Subdomains” thing in the feature table doesn’t apply for you, it’s only for free subdomains from us, like example.epizy.com, that are not supported.
And if it’s not supported, you won’t be able to choose the SSL provider in our panel, and it definitely won’t show as recommended.
