Hi,
I would like to know what versions of PHP are currently supported by infinityfree, and if known, what the roadmap is in the short-term, in terms of removing support for older versions.
Many thanks in advance
Hi,
You can find the latest supported version on your site’s control panel.
And regarding roadmap, couldn’t tell for sure but I think infinityfree would support as much PHP version as possible until that version reach EOL.
Thanks Joo_Nath
