Suspendeddomain.org/?
Hello,
I just had a tidy up and might have removed something that was required or its possible there is an error not related to changes I have been making.
I have two domains that are both pointing to iFastNet.com Special offer and Discount Coupon ?!
fixa.services
http://fixa.epizy.com/
fewcharecords.com
http://fewcharecords.epizy.com/
epizy domains work fine but other domains doesn’t. it looks you haven’t added domains to your sites.
Do you mean under domain → addon domains?
yes.
Edit: I dig up your domains and they’re not pointing to correct nameservers.
I checked on my pre-configured DigWebInterfaces (links above) and the first domain’s nameservers aren’t correct, while the second ones are correct. Please change them to ns1.byet.org, ns2.byet.org, ns3.byet.org, ns4.byet.org and ns5.byet.org from your domain registrar’s nameservers management panel for your first domain, wait 30 minutes to 24 hours for the nameserver changes to be propagated and then add your domains from either the “Addon Domains” or the “Parked Domains” section of the Control Panel in order for your websites to not point anymore to suspendeddomain.org and be fully working.
i think i have it guys thanks for your help :slight_smile:
