Temporary Solution to PHP Error - ZipArchive and more
Currently there are Problems with PHP 7.x with Errors such as ZipArchive and other Extensions, the Temporary Solution is to go to the Control Panel, Select “Change PHP Version” and Choose Version 5.5 or any other that is NOT Version 7.x .
Screenshot_2
Screenshot_3
For more information on the topic, see this: Website / PHP issues following PHP upgrade
Thanks to User FutureInformatic for the Advice that I am now Sharing with ALL of you colleagues.
But it may don’t work to applications that use unserialize() PHP function.
It is a Temporary Solution until iFastNet Solves the Current Problems of PHP 7.x
