Hello, i was able to import a small test mysql db to InfinityFree -
Now i want to access this db with python using sqlalchemy
Therefore i try to establish the connection with this statement:
engine = create_engine ("mysql+pymysql://epiz_26274076:[email protected]:3306/epiz_26274076_testdb")
Using the parameters according to the sqlalchemy docu:
dialect+driver://username:password@host:port/database
But everytime i try to run the code i get an error:
ConnectionRefusedError: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte
Any ideas what can be wrong here?
This is my whole test code:
from sqlalchemy.sql import text
from sqlalchemy import create_engine
#engine = create_engine ("mysql+pymysql://root:(HIDDEN BY MOD)@localhost/stockdb?host=localhost?port=3306")
#engine = create_engine ("mysql+pymysql://epiz_26274076:(HIDDEN BY MOD)@sql100.epizy.com/epiz_26274076_testdb")
engine = create_engine ("mysql+pymysql://epiz_26274076:(HIDDEN BY MOD)@sql100.epizy.com:3306/epiz_26274076_testdb")
conn = engine.connect ()
lst_stock_incstat = []
t = text ("select * " # 0, 1
"from actor where actor_id < :w")
result = conn.execute (t, w=10)
