Hi Guys,
can someone please test this link, and send me a screenshot? as the website is not showing up, I cleared my cache a couple of times and it is still not working.
Hi Guys,
Hello there,
It is working on my end:
But I don’t know if this is what it should look like. But it seems broken? You might want to recheck your CSS and JS files.
And also could you consider flushing your DNS cache as well? Or try visiting your site on another browser or device?
how do you flush you DNS?I tried on another device,still did not work.
For Windows, execute this command in the Command Prompt or Windows Terminal.
ipconfig /flushdns
For MacOS, you may refer here:
You actually need to refresh browser cache instead of DNS cache. If you are on PC, click Ctrl+F5. If you are on mobile, just hit refresh a few times. If it doesn’t work, try after sometime.
He already did though I think:
Glad that it is working.
EDIT: Can you mark this topic solved?
No, only you can.
How I can? I have not started this topic.
