The certificate is not trusted by all web browsers
my site mline.eu.org
Hi!
I installed ssl on my website and it worked, but when I tried to open the website on fire fox, edge and android and it was giving a security error, then I went to check my domain on the website: https: //www.sslshopper .com / ssl-checker.html # hostname = mline.eu.org, and I found this error: The certificate is not trusted in all web browsers, please someone help me with this problem, my website is: mline.eu .org
Using Cloudflare can sort this issue for most browsers.
EDIT:
Don’t use ZeroSSL. Use InfinityFree’s SSL Tool. Lets Encrypt Certificates have a much higher browser support and you can have as many as you want for free.
Will only work on custom domain
thanks
How can I do to use the InfinityFree SSL tool
my domain is personalized
and how can i use the cloudflare ssl in infinity free
This may help
Just go to the tool and read the instructions on screen?
We try to make our tools easy to use. We try to make it so that you don’t need an expert to personally guide you through the process, because they should be so easy anyone can use them. Just carefully read the instructions provided and pay attention to what you’re doing and you’ll be fine.
