The key uses greater than 2048 bits
When I wanted to add the Private Key (KEY) created by the Really Simple SSL Plugin automatically:
I got this error:
There is no need to install those Key provided by Really simple SSL , Just follow the steps provided as per the documentation by admin
Like the error message says: the private key generated by Really Simple SSL is bigger than what our control panel accepts.
If Really Simple SSL has the option, you should configure it to use 2048 bit keys. If Really Simple SSL doesn’t have that option, you can’t use the keys they generated.
We also provide free SSL certificates through the “Free SSL Certificates” system in our client area. That system was designed to work with our hosting, so you can be sure that everything will work!
