The MySQL Connection could not be established
epiz_29896043 Website URL otherside.lt
Cant install wordpress
The following errors were found :
The MySQL Connection could not be established.
Yeah. This is an error on InfinityFree’s side as I’ve been receiving these consistently recently. I’d wait for them to reply.
Ok. Lets wait support answer :sweat:
Yes, I’m not sure how long it will take but I’ve been getting these errors for the past few days which has disabled me from continuing to do anything. Just be patient and it will be solved.
My theory behind this is that one (or more) of their databases is not working as intended and thus it is giving out these errors. It wouldn’t surprise me if they don’t declare this as a system outage at some point soon.
Once again, just be patient and it will be fixed soon hopefully.
@Charon, welcome to the fam!
There’s some issue with the database server again, I guess. Patience is needed,
That was my thoughts, is everyone getting the same error?
Any specific error code, perhaps?
Not currently, it’s appearing everywhere and it’s now happening when trying to install any software from Softaculous.
Hmz looks like now started work. Its installed without errors :sparkling_heart:
Yes, the issue seams to come and go, so don’t be surprised if it reappears. If it does, simple reply here so it can get looked at.
All evidence I have so far (which is very little, other than “there are database errors”) points to a congestion issue. So at busy times, you may get errors, but on other times not. I haven’t seen a single error for myself, for example.
