Too Many Redirects PhpMyAdmin
Username epiz_27072037
[ERR_TOO_MANY_REDIRECTS]
When i’m trying to access PhpMyAdmin for my db named: epiz_27072037_autoservice24 , i get an error… I have deleted the cookies and even made new db…
How are you trying to access it? What URL?
#1 I’m in cpanel, DATABASES → phpMyAdmin → Connect now!
URL: http://185.27.134.10/login.php?2=epiz_27072037wejghelqwdtg3e54gVFhwbk1VOVVXVFZPVkVFeVRWaDNhRWxUUldoSldIZzRaa2g0T0daSWVEaG1TSGN5WVROQ2RXVkhaREpPUVQwOQ==wejghelqwdtg3e54gsql301.byetcluster.comwejghelqwdtg3e54gepiz_27072037_testowa&db=epiz_27072037_testowa
#2 In cpanel, DATABASES → MySql Databases → Admin
When i got error on the screen the url is: http://185.27.134.10/db_structure.php?db=
Console:
Can you try using incognito mode?
This helps:
Funny thing is that i have done all the stuff from this site :slight_smile: step by step of course, not all at once.
AAAAAANDD STILLLLLL :joy: this f… error show.
Anyone? please…
All I see is because your password permission is corrupted, it can be fixed with changing password of your site through clientArea (ClientArea->your site->edit account)
Today i tried on another PC, i didnt save any logging data, and the same thing… but i noticed that when i’m on app.infinityfree.net, choosing the account and cllicking Control Panel, it’s showing the message : "We are unable to log you in with the information you provided. Please check your username and password and try again 1 "
As you sad @anon19508339 i changed the password that i had in the accounts details and now it’s working fine. I though that if i’m changing password it should automatically change it every where…
FOR EVERY ONE THAT ARE FACING THE SAME PROBLEM CHANGE IT MANUALLY IN THE ACCOUNTS SETTINGS. NOT MAIN ACCOUNT ON THE INFINITYFREE BUT ACCOUNT FOR YOUR WEBSITE.
Well, that’s why we NEVER tell you to reset your password through password reset option, it’ll just ruin your account permissions.
But this option is for it, right? So it should work … That’s an task for developers to fix it in my opinion.
Well look, if there was option to remove these, this feature would’ve removed.
