Too many redirects
Username: epiz_25958448 or Website URL: https://myseospecialists.com/wp-admin
I’m using WordPress
Error: Try clearing cookies, too many redirects
Whenever I try to open dashboard/admin panel of my wordpress website by using wp-admin, I’m getting this error.
I have tried with wp-login.php but it takes admin login details and after that it redirects to same wp-admin and showing same error message.
I have also tried to change directories of themes and plugins from file manager of host. But still tha same issue.
Thanks but still couldn’t resolve the issue.
I’m using WordPress
I have also tried this but still same issue. How to make Cloudflare Flexible SSL work with WordPress - Docs - InfinityFree Forum
Hey there,
Your website’s dashboard login page works fine for me. Try clearing your cookies and browser’s cache. These might help you:
Best Regards,
Dimitris
Yes but after entering login details it shown again same issue and redirects to wp-admin
That’s weird. The only thing I can suggest you then is to uninstall and re-install wordpress.
Please let me know if this helped
Hey friend your error is solved if solved then tell me because I also have same
I have an active wordpress installation and I don’t experience problems like yours. Can you try uninstalling and re-installing wordpress using softaculous? or if not working with softaculous trying to install it manually from wordpress.org
Let me know if this helped :wink:
