epiz_27096081
Hello there,
I am having trouble connecting the above mentioned domain to a custom domain which I bought through Strato.
I understand that I have to add infinityfree’s DNS name server to the domain-provider (in this case Strato). If I do so, I get the following error message from Strato: “An error has occurred. The specified name server is not responsible for this domain.”
Does anyone know, why this is happening and what to do about it?
I already have another domain on that same infinity account using a custom domain from another provider (in this case IONOS) as well and there it was no problem setting up the name-servers.
Hope anyone can help.
Kind regards,
Andrea
KangJL
August 12, 2021, 4:16pm
#2
Since you have posted vague question, I can only refer you to these
If you currently have a website with another hosting provider, you may be wondering: how do I transfer everything to InfinityFree?
To answer that question, it’s important to note the difference between a Hosting Account and a Domain Registration.
A Domain Registration gives you the ownership of a particular domain name (e.g. example.com ), and enables you to make services like websites and email addresses available on that domain. However, a domain registration itself does not provide those se…
While a free subdomain is a great way to get started, a website looks a lot more professional with a custom domain name. Fortunately, you can register your own domain name with an external company (like NameSilo ) and use it on InfinityFree.
There are multiple ways you can add the domain name as an account. You can create it as a new account or add it to an existing account.
Before you start: configure your domain’s nameservers
Before you can add the domain name to your account, you need to ve…
Before you can add a domain name to your account, you need to point it to the InfinityFree nameservers first. However, some domain providers show an error like this when trying to change the nameservers:
DNS Query Refused
If that happens, your registrar will tell you that the nameservers must be configured first.
What causes this issue
Before you can add your domain to your InfinityFree account, you need to verify you can control the domain. The only way to do so right now is by setting th…
Before you can add your domain name to your hosting account, you need to point it to the InfinityFree nameservers.
The nameservers of your domain name are a setting at your domain registrar to allow you to host a domain name with a different provider. So you need to change these settings at the site where you bought your domain name. Most registrars have different panels and we can’t cover them all in this guide. For this guide, we’ll use NameSilo as an example.
Step 0: Find the correct names…
Admin
August 12, 2021, 5:44pm
#3
This topic may be relevant too:
I don’t think you can host your .de domain with us.
Even though you can point the domain name to our servers, our servers don’t know which account and website that domain name is related to. To do that, you need to add the domain to a hosting account. And to add the domain to a hosting account, you must change the nameservers of your domain to point to our servers first.
The .de extension is specifically listed in our article about “annoying domain extensions which are really picky about names…
Hello there and thank you for your reply.
The domain I want to use for the above mentioned website is a .com - domain, just the domain-provider is German. And you said “Even though you can point the domain name to our servers” - that’S exactly the problem. I CAN NOT point the domain name to infinity free’s server, because I get an error when I add the DNS names to the domain provider. And I was wondering If there is any other way, to connect my custom domain to the infinity free webspace?
Kind regards,
Andrea
This is probably stopping you.
DNS Query Refused
You can transfer your domain to someone else, and set your nameservers on a provider that allows it.
system
Closed
August 23, 2021, 12:44pm
#7
