Everytime i try to connect to my website ftp it gives me this error
Connection attempt failed with “EAI_NONAME - Neither nodename nor servname provided, or not known”.
I have entered the correct ftp credentials
Can I ask what you’ve put as the FTP Server, because it seems like your software thinks there isn’t one.
Are you using FileZilla? If so, can you please share the full logs?
Status: | Resolving address of ftpupload.net |
Status: | Connection attempt failed with “EAI_NONAME - Neither nodename nor servname provided, or not known”. |
Error: | Could not connect to server |
Status: | Waiting to retry… |
Status: | Disconnected from server |
Could you please try the FTP hostname ftp.epizy.com
instead? It points to the exact same server.
For some reason, some ISPs and/or network administrators hate our FTP hostname and block it. That’s the only reason I can think of that the hostname ftpupload.net
doesn’t work.
worked tnx
Status: | Retrieving directory listing… |
Status: | Directory listing of “/” successful |
Status: | Connection attempt failed with “ECONNREFUSED - Connection refused by server”. |
Status: | Connection established, waiting for welcome message… |
Response: | 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- |
Response: | 220-You are user number 449 of 6900 allowed. |
Response: | 220-Local time is now 04:52. Server port: 21. |
Response: | 220-This is a private system - No anonymous login |
Response: | 220 You will be disconnected after 60 seconds of inactivity. |
Command: | AUTH TLS |
Status: | Resolving address of ftp.epizy.com |
Status: | Connecting to 185.27.134.11:990… |
Error: | Connection timed out after 20 seconds of inactivity |
Status: | Connection closed by server |
What is your domain?
Hmm, that’s definitely a network problem on your end. A configuration issue there can cause problems in the AUTH TLS step, which is where the connection encryption is set up.
Can you please try the instructions from this section down?
