Hello. I am unable to delete a certain folder off the server. When I try, it states that the folder is not empty and it is unable to process it. Not FTP nor Cpanel software helps with deletion.
@anon55589970 The directory /htdocs does not exist or could not be selected, so the directory / is shown instead. I’m getting this error when I’m trying to open htdocs directory.
@bbot22 I tried to add domain in another account but after installing wordpress when I’m trying to login I’m getting this error. The requested URL /wp-admin/ was not found on this server.
Your WordPress installation will always be under a children direction inside the “htdocs” folder.
If htdocs folder has no folders, if you delete folders under htdocs folder then go to Softaculous Script Installer and just install WordPress again under main directory. No Sub-directories.
@anon55589970 I’ve not changed permission and I’m not able to change the permission of htdocs directory. I’m getting the error permission denied when I’m trying to change the permission.
That error page is not from our servers. It says Apache 2.4.29 running on Ubuntu. We don’t run Ubuntu and we don’t run that specific version of Apache.
Your website is working fine from here and your DNS settings look OK. Do you experience this issue on other devices. Have you edited the hosts file on your computer before?
