Hi Folks,
After adding the InfinityFree NS to my domain configuration and uploading my web files my website URL displays the directory with all the codefiles instead of the index page.
Can someone please help?
Hi Folks,
Try editing your .htaccess file and add:
DirectoryIndex index.php index.html index.htm
Can you please share the domain?
Make sure the page is called “index.html” or “index.php” exactly.
@wackyblackie, that .htaccess code is pre-installed.
@NetSkills, I sent you a private message, please share your domain name there. A DDoS attack is happening on the servers, and if you post you domain publicly it may be attacked.
Thanks @Greenreader9 I realized my file name was index.aspx which probably was creating the problem.
Good to know that it was just a small issue! Just remember, ASP is not installed here at InfinityFree, only PHP.
