Under construction page wont go away
Under construction page wont go away, im thinking is that it cant find the index.html when its there. Any help? would appreciate it now
Hi and welcome to the forum
Your site is currently using Cloudflare
try to purge all cache there
Also make sure that in the DNS section on CF your domain points to this IP 185.27.134.206
of course, check all other settings on Cloudflare !
I have purged all cache, i need to pay to add custom NS to the cloudflare DNS so i cant do it, i tried pointing the domain to the IP via registrar NS but that said invalid. Im thinking that i put the SSL Certificate on the domain toxihosting.com instead of putting it on stuff like Toxi Hosting - home or something like that, but its still the same and now nginx has taken over some pages
Actually i tried the solution i thought was right and it wasnt, so i would like some help
Not NS but IP
Cloudflare is currently your DNS provider
and in it… in that section there
where you added your domain should be the IP I mentioned
if it is not that IP then edit it (185.27.134.206)
why I think that CF does not refer to this hosting is because I see that I am not getting one specific file
Make a screenshot so we can see what data you have there in CF (DNS)
apart from that, that 503 is a bit strange to me
I don’t know if CF generates it for some reason or…
And you can give us the .htaccess file (copy paste) just in case, if you have a custom one that you uploaded here to the hosting
TYSMM, pointing to the IP fixed it!
.htaccess is
ErrorDocument 400 linkhttps://toxihosting.com/400.html
ErrorDocument 401 linkhttps://toxihosting.com/401.html
ErrorDocument 403 linkhttps://toxihosting.com/403.html
ErrorDocument 404 linkhttps://toxihosting.com/404.html
ErrorDocument 503 linkhttps://toxihosting.com/503.html
DirectoryIndex index.html
Do you still want the DNS data?
No, there is no need if your problem is solved.
Good luck in your future work and thank you for choosing this hosting :slightly_smiling_face:
