Website URL
Can I uninstall WP multisite plugin (WPCentral) without reinstalling everything?
WP Central, isn’t a multisite plugin. It gives you one dashboard to manage multiple sites. You can remove it from the plugins section of the dashboard. Though I strongly recommend to take a backup first.
thank you for your quick reply. I am actually trying to switch from the multisite installation to a standard single one due to incompatibility issues. What’s the best way to go about that?
I cannot find the wp central plugin in the dashboard btw…
You said you are using WPCentral as your multisite plugin:
So this wasn’t actually the official way to do it. To uninstall it, you should go to the plugins section of your dashboard:
and then click "deactivate"and after that “delete”.
I mentioned WPCentral because within the infinity WP installation process we have the possibility to enable multisite and next to this option there is a ? indicating that this addon is basically installing the WPCentral plugin (when you go to details)…
This plugin is NOT available in my plugin area, hence my request…
no I don’t. just the main site
Follow this guide:
