http://apado.ml
When opening with HTTPS :
This site can’t provide a secure connection
apado.ml sent an invalid response.
When upload certificates :
The certificate you have entered does not match the current private key.
I can’t enable SSL on the websites. It only show not secure on the top left. I alr get a certificate on Infinityfree. What the problem?
KangJL
#2
Since SSL certificate is not installed, this is expected
Is the private key from InfinityFree as well?
Both certificates and private key from Infinityfree.
Can you send a screenshot of the following?
The control panels SSL/TLS section (Where you paste both keys, please make sure all three boxes are visible)
The screen that provides you with the keys on the InfinityFree client area.
Thanks.
Pls help me to make my site with HTTPS
KangJL
#10
Please re-upload the private key. Then install the SSL cert.
system
Closed
#11
