Upload Limit on Net2Ftp
Hello, I have a script (90+ MB) which is used to make HTML stuff (CLEAN SCRIPT!).
And on Net2ftp the limit is 10MB, but if i want to upload my script, this means i have to split my script into a lot of Zip’s files which will be a stressfull one due to the directories on it.
Please gave me a free solution thanks.
Exactly.
You have to do it like that.
Use FileZilla to connect to FTP, you can just extract the zip and drag the entire directory to the server. By doing so, you’re still uploading the files individually, but FileZilla handles all the heavily lifting.
